je viens d'asquérir un poste VHF d'occasion sur un site de vente en ligne pour suppléer ma CB en raid à l'étranger.
Je sais qu'il faut une licence et ne pas encombrer les ondes, mais pour des raisons de sécurité et un usage trés trés occasionnel...
Merci de ne pas m'affliger mais plutôt de me donner des conseils pour ne pas faire de bétise.
ICOM IC-2100H 55W VHF Mobile
This is a used ICOM IC-2100H in GREAT condition. It was bought in US in 2002. There is no scratch and work fine. The radio is delivered with original box, mounting bracket, HM-133S DTMF microphone, 12VDC cable, and manual.
Receive: 136-174 MHz
Transmit: 144-146 MHz
Variable Output Power;
High: 55W
Mid: 10W
Low: 5W
14 channels for 16-digit DTMF codes
113 Memory Channels
External Speaker Port
Automatic Repeater Shift
Memory & VFO Scan functions
Programmable Call Memory
Priority Watch
DTMF
Tone & CTCSS squelch (NO DCS)
Wireless Operation with optional accessories (not supplied)
Time Out Timer
Auto Power Off
Selectable Display Color (Green or Amber)
Selectable squelch delay
MARS/CAP Capable
SPECIFICATIONS:
General
TX Frequency Coverage: 144~148 MHz
RX Frequency Coverage: 136-174 MHz
Output Power: 55 W, 10 W, 5 W selectable
Mode: FM
Memory Channels: 113 (inc. 3 pairs of scan edges, 3 log, 3 repeater, and 1 call channel)
Usable Temperature Range: -10°C to +60°C; +14°F to +140°F
Frequency Stability: ±10 ppm (-10°C to +60°C)
Power Supply Requirement: 13.8 V DC ±15% (negative ground)
Current Drain (at 13.5V) Transmit: 12.0 A (55W)
Current Drain (at 13.5V) Receive: 1.0 A (max. audio output) 0.8 (standby)
Antenna Connector: SO-239 (50ohms )
Dimensions (projections not included): 140(W) x 40(H) x 180(D) mm, 5.5(W) x 1.6(H) x 7.1 (D) in Weight: 1.2 kg; 2 lb, 10 oz,
Transmitter
Output Power: 55, 10, 5W selectable
Maximum Frequency Deviation: ±5.0kHz.
Spurious Emissions: Less than –60dB
Microphone Connector: 8-pin modular (600ohms)
Receiver
Receive System: Double-Conversion Superheterodyne
Intermediate Frequencies: 1st 15.65MHz., 2nd 450kHz.
Sensitivity (at 12dB SINAD): Less than 0.18mV
Selectivity (Wide/Narrow):
More than 12kHz at –6dB
Less than 28kHz at –60dB
Spurious & Image Rejection: More than 60dB
Intermodulation Rejection: More than 70dB
Audio Output Power (at 13.8V DC): More than 2.4W at 10% distortion with an 8ohms load
Ext. Speaker Connector: 3-Conductor 3.5 (d) mm (1/8”) 8ohms
Bref je ne sais pas comment çà marche et j'attend de la recevoir pour me plonger dans la notice.
En attendant j'aimerais que vous puissiez me conseiller sur le choix d'une antenne (modèle, longueur d'onde, dimensions...) pour mon LC95 qui corresponde au mieux à ce poste. Celà pourrait être une magnétique ou fixe.
Magnétique me semble bien car usage trés ponctuel mais j'en ai un peu assez de la voir s'envoler comme mon antenne CB (rayures capot). Poser une base à demeure par perçage, fixation sur goutière ou capot, pare choc, barre de tente de toit?
Vos conseils me seront précieux.
