Donc, je voulais savoir si y'en avait qui pensait à se prendre le kit Méasson cette année
A++
Modérateur : romainletu
Demande à Elysé, et fais une recherche il a fait un c.r. trés clean du produit.NELSON60 a écrit :T'en ai content ???
Pas encore eu le temps de le tester....NELSON60 a écrit :T'en ai content ???
+1pat 25 a écrit :+1, je ne vois pas l'intérêt qu'il y a , a mettre un kit qui vaut plus de la moitié du Sam.
Super Jimny a écrit :[img]http://www.suzuki4x4products.com/nieuwe ... ion_qte3[1][/img]
Super Jimny a écrit :Spidertrax Quarter Elliptical Rear Suspension
The Spidertrax Quarter Elliptical Rear Suspension (QERS) is the ultimate solution for true offroad performance. With its CAD design and over 6 years of trail testing, its easy to see why this suspension is setting the standard for Suzuki aftermarket products everywhere. With superior axle articulation and control, its hard to believe that this suspension is easy to install. However, making the product installation friendly was a top priority from the start. The heart of the kit lies in the two pre-welded chassis sideplates. These sideplates incorporate the springs, lower links mounts, and upper link mounts which ensures the dynamics of the suspension stay consistent from vehicle to vehicle. The sideplates also have alignment pins so the sideplate is ""self-aligned"" to the chassis during the installation. The QERS includes all links, tabs, rod ends, mounting plates, shock mounts, pivoting shackles, bumpstops, a limiting strap, hardware, and springs needed for the install. The QERS also includes detailed instructions to make the installation of the kit easy to follow. Although this is a weld on kit, a majority of the kit is pre-welded. Shocks (Rancho 9012's are required) and extended brake lines are sold separately.
S0103013 Spidertrax Quarter Elliptical Rear Suspension € 1462.84 (incl. 21% VAT)
Ba en faite, quite à mettre un kit suspension de merde à 1000€, autant en rajouter le double pour avoir le sumum !!!pat 25 a écrit :+1, je ne vois pas l'intérêt qu'il y a , a mettre un kit qui vaut plus de la moitié du Sam.
