sonde pression d'huile
man71
Message par man71 »
salut à tous
donc ma sonde ne fonctionne pas et j'ai trouvé son fils coupée donc je l'ai rallongé et branché mais ne fontionne toujours pas. :confused:
3 questions:
comment tester la sonde?
comment tester la connection? (le fils)
y a t'il un fusible pour cette seule sonde puisque tout le reste marche ?
merci pour vos remarques eclairees.
Manu :cool:
man71
re: sonde pression d'huile
Message par man71 »
:confused: y a personne. :confused: :confused: :confused:
Pat
Message par Pat »
T'inquiete :D
Pour les cas desesperés j'ai des trucs :diable:
Oil Pressure Gauge & Harness Operational Test (1995 4Runner)
1) Unplug oil sending unit connector on engine. Turn ignition
on. Oil gauge should indicate LOW. Turn ignition off. Connect a 12-
volt, 3.4-watt test light between oil sending unit harness connector
terminal and ground.
2) Turn ignition on. Test light should glow and oil pressure
gauge should slowly move to HIGH. If gauge functions as described,
perform SENDING UNIT OPERATIONAL TEST below. If gauge does not
function as described, perform OIL PRESSURE GAUGE RESISTANCE TEST
below.
Sending Unit Operational Test (1995 4Runner)
Unplug oil sending unit connector on engine. Using 12-volt
source, connect LED tester between positive battery terminal and
sending unit. With engine off, LED should not light. With engine
running, LED should flash. LED flashes will vary with engine speed and
oil pressure. Replace sending unit if LED does not function as
described.
Oil Pressure Gauge Resistance Test (1995 4Runner)
Remove instrument cluster. See INSTRUMENT CLUSTER under
REMOVAL & INSTALLATION. Using an ohmmeter, check resistance between
oil gauge terminals on rear of instrument cluster. See Fig. 2, 3, or
7. See OIL PRESSURE GAUGE RESISTANCE SPECIFICATIONS table. Replace
gauge if resistance is not within specification.
OIL PRESSURE GAUGE RESISTANCE SPECIFICATIONS TABLE
Application Ohms
1995 4Runner .......................................... 25
Pour les modos récalcitrant qui y verrait du copyritgh, ces infos sont à dispo chez MAP (motor assurance Program) with the courtesy of Toyota Inc :p
cedricfred
Message par cedricfred »
T'as déjà vu des modos récalcitrants chez Toyota ? :p
Oui ou alors Arroser qui passerait faire un tour :no:
Mais bon là même si c'était avec copyright c'est un p'tit bout de texte tout bête faut pas exagérer.
man71
Message par man71 »
slt et encore merci à PAT :p
mais il va me falloir quelque temps pour arriver au bout de ton explication :hein:
mais je vais m'y coller. :D
Manu.
