GC 4.7 2001 - boite 4 ou 5 rapports?
Modérateur : valJeep
GC WJ 4.7 2001 - boite 4 ou 5 rapports?
Je fouille sur le net à la recherche de ma future et j'arrive pas à savoir si la boite auto sur un 4.7 LIMITED de 2001 est à 4 ou 5 rapports
D'après ce que je lis ici http://www.wjjeeps.com/newoptions.htm#2001
A partir de 2001 il y aurait 5 rapports via une "reprog" !!?? de l'ancienne boite à 4...
Automatic transmission, new 545RFE five-speed with 4.7-liter engine provides a second overdrive ratio for increased highway fuel economy and reduced engine noise at highway speeds (Note: A Flash upgrade was introduced on September 15, 2000 which when performed on 1999 and 2000 models adds the new second overdrive ratio to upgrade those transmissions to 5-speeds)
On en parle ici aussi http://en.wikipedia.org/wiki/Jeep_Grand_Cherokee
The 45RFE and 545RFE automatic transmission in the WJ was notable. It included three planetary gear sets rather than the two normally used in a four-speed automatic. This gave it six theoretical speeds, and it would have been the first six-speed transmission ever produced in volume, but it was programmed to only use five of these ratios. Four were used for upshifts, with a different second gear for downshifts. Although five of the six ratios were used, Chrysler decided to call it a "4-speed automatic". In 2001, the programming was changed to make use of all six ratios. Rather than have six forward gears, the transmission was programmed to act as a five-speed with the alternate second gear for downshifts. The rpm at 70 miles per hour (110 km/h) on a 545RFE is 2000 rpm, 200 rpm less than the 45RFE programming. 1999 and 2000 model year WJ owners can have their 45RFE transmission's programming flashed to enable the extra gear as both transmissions are physically the same. The 42RE 4-speed automatic remained the transmission for the Inline 6 engine. It had slight changes from the previous model Grand Cherokee.
Quelqu'un en saurait il d'avantage?
En 2001, les 2 boites auraient t'elle existées?
Le tout sur 4.7 LIMITED non HO
Merci pour votre aide
- ZaZou
re: GC 4.7 2001 - boite 4 ou 5 rapports?
Merci pour ton infoZaZou a écrit :Sur mon "ex" 60ieme anniversaire, donc 2001, j'avais 4 rapports + overdrive
Je n'ai jamais eu de BA donc mes questions risquent de paraitre débiles...
4 rapports + overdrive ca donne donc 5 rapports non?
L'overdrive est bien un rapport engagé tout seul par la boite au dessus d'un certain régime moteur à une certaine vitesse non?
Une boite 5 rapports a t'elle alors 5 rapports + overdrive?
- Bebop
ouaismic57 a écrit :A partir de 2001 il y aurait 5 rapports via une "reprog" !!?? de l'ancienne boite à 4...
La magie des boites auto
En gros, sur la 45RFE tu as 4 marches AV (3 rapports + OD d'ou le terme BVA 4), une deuxieme seconde (
Sur la 545RFE, tu as 5 marches AV (4 rapports + OD d'ou le terme BVA 5), une deuxieme seconde (re-
La cinquieme est inhérente au fonctionnement électronique, et il est tout à fait possible de reflasher le TCU et d'utiliser la cinquième sur une BVA 4 (donc pré-2001).
ça te parait surement bizarre, mais si tu regardes comment une BVA fonctionne (avec ses jeux de planétaires), tout prendra du sens
OkBebop a écrit :ouais
En gros, sur la 45RFE tu as 4 marches AV (3 rapports + OD d'ou le terme BVA 4), une deuxieme seconde () pour le retrogradage et une marche AR.
Sur la 545RFE, tu as 5 marches AV (4 rapports + OD d'ou le terme BVA 5), une deuxieme seconde (re-) pour le retrogradage et une marche AR.
ça te parait surement bizarre, mais si tu regardes comment une BVA fonctionne (avec ses jeux de planétaires), tout prendra du sens![]()
En fait j'ai contacté un vendeur pro qui propose un 4.7 de juin 2001 et qui me dit que c'est une boite 4
Or j'ai lu qu'à partir de 2001 c'est la boite 545 RFE qui est montée, donc 5 rapports
c quoi le bin's?
- Bebop
c'est peut être que le vendeur y connait rien aussi... ça arrive très fréquemment.
Y a t'il un moyen visuel de voir ça sans essayer le véhicule et compter les vitesses ? sur le levier? l'encadrement de la commande de boite??
- valJeep
- Localisation : entre sauvignon et chardonnay :D pays d'Ancenis ;)
Je me suis permis de regarder d'un peu plus près le principe, et il faut quand même que la BV ne soit pas au taquet si on veut pouvoir gagner un overdrive avec un rapport de transmission plus élevéBebop a écrit : ça te parait surement bizarre, mais si tu regardes comment une BVA fonctionne (avec ses jeux de planétaires), tout prendra du sens![]()
SJ 413 de 2002, , 65mKm
Je pige pasvalJeep a écrit :Je me suis permis de regarder d'un peu plus près le principe, et il faut quand même que la BV ne soit pas au taquet si on veut pouvoir gagner un overdrive avec un rapport de transmission plus élevé![]()
- valJeep
tu comprends comment fonctionne un train épicycloïdal?mic57 a écrit :Je pige pas
