ça capte moins bien en gdes ondes! passkekoi?
bismuth
re: ça capte moins bien en gdes ondes! passkekoi?
#51
Message par bismuth »
BOITES de vitesse et transfert : 75w90 API GL 4 :cool:
bismuth
sur le CD "atelier" Nissan
#52
Fluids and Lubricants Capacity / Recommended fluids and lubricants
Engine oil (Refill)
With oil filter TD27Ti 6.2 5-1/2 API CE, ACEA B2-96 (CCMC PD1), D5 level
SHPD (*1) Without oil filter TD27Ti 5.5 4-7/8
Cooling system Total capacity
(With reservoir tank)
TD27Ti 10.0 8-3/4
Anti-freeze coolant
(Ethylene glycol base)
ZD30DDTi 10.6 9-3/8
Genuine Nissan Anti-freeze Coolant (L2N) or
equivalent*5
Manual transaxle gear oil
FS5W71C 3.5 6-1/8 pt API GL-4 (*1)
FS5R30A 3.6 6-3/8 pt API GL-4 (*1)
Transfer TX10A 2.3 2 API GL-4 (*1)
Differential oil
R180A 1.3 2-1/4
STANDARD:
API GL-5 (*1)
H233B
(LSD)
2.8 4-7/8
Use only LSD gear oil API GL-5 and SAE 80W-90
(*2) approved for NISSAN LSD
Power steering fluid 1.0 7/8 DEXRONTM
Brake and clutch fluid — — DOT 4 (USFMVSS No. 116)
Multi-purpose grease — — NLGI No. 2 (Lithium soap base)
Air conditioner system
refrigerant R134A
KLH00-PAGRO lubrication oil
*1: For further details, see “SAE Viscosity Number”.
*2: SAE 90 is acceptable in ambient temperatures above −18°C (0°F)
*3: Do not mix automatic transmission fluid and gear oil.
*4: Never use API CG-4.
*5: Use Genuine Nissan Anti-freeze Coolant (L2N) or equivalent in its quality, in order to avoid possible aluminum corrosion within
the engine cooling system caused by the use of non-genuine engine coolant.
voili, voilou, comme dirait Serge ! :diable:
Tanguy
#53
Message par Tanguy »
j' aime bien l' anti frise coulant.... :D
bon , bref !
dans vos T2 il rentre 6l d' huile 75W90 au total dans la boite de V. et de T.
si il y a 1/2 L. d' huile 80W90 ça va pas lui bouleverser la vie .... mais c' est pas bien quand même , l' essentiel étant que les 2 huiles mélangées aient les mêmes catarc ...euh non , ratasco ...euh non , crataca .. euh non RRAAaaah ! :rah: ca-rac-té-ris-tic ! voilà :D
ou minérale , ou synthèse , ou margarine ..
pas de mixage entre tout ça
voili , voilou :cool:
mais faudra pas recommencer ! non mais dis donc .... :D
bismuth
#54
Tanguy a écrit :j' aime bien l' anti frise coulant.... :D
bon , bref !
il a oublié voili, voilou ! :no:
"bismuth, ca c'est fait" :devil:
didi
#55
Message par didi »
didi a écrit :Ouais, ben quand on met un cibi dans une auto, si on met pas un shadock c'est normal que ça marche pas... :D vous savez les cibi, ceux qui mangeaient des carottes et qui avaient une robe avec des carottes ou qui mangeaient des petits pois et qui avaient une robe avec des petits pois... :D
on l'avait déjà faite celle là peut être!? :(
:( aller, bouyou les gars!
moi j'suis en vacances!! et Youpi. :eek:
oui, huile synthétique. il y a juste un fond de "c'est pas écrit dessus" mais en apiGL5, quand même.
Bon,sinon, quand je soulève un problème sérieux, faudrait peut être voir à voir! :) aller bouyou les gars.
Jpars demain à Concarneau, j'espère qu'il y a des chemins ou kon peut aller :o
Tanguy
#56
bon , bref !
bismuth a écrit :il a oublié voili, voilou ! :no:
c' est l' âge qui commence à faire ses ravages ! :lol:
Tanguy
#57
didi a écrit :oui, huile synthétique. il y a juste un fond de "c'est pas écrit dessus" mais en apiGL5, quand même.
si à la prochaine vidange tu as des boulettes de graisse qui tombe , cherche pas d' où ça vient :D
à Concarneau , ya des bigorneaux :eek:
tiens ? comment s' appellent les habitants de Concarneau ? ? :hein:
bismuth
#58
Tanguy a écrit :c' est l' âge qui commence à faire ses ravages ! :lol:
oups !! :redface: :redface:
oui mais quand même .. il faut le mettre à la fin de ta prose , sinon ca compte pas ! :raleur:
Bonnes vacances didi :)
bismuth
#59
Concarnois
Tanguy
#60
bismuth a écrit :oups !! :redface: :redface:
oui , en effet .... justement je me tatais pour savoir ou le mettre :hein:
car là aussi c' est l' âge qui est en cause
.... quand la prose tate !
:lol: :lol:
