préparation d'un T2 pour les dunes
sparkybg
- Date d’inscription : octobre 2010
re: préparation d'un T2 pour les dunes
40250-88G00/40250-88G01/40250-2S610 - Terrano 1/Pathfinder with VG30E engine (after 1988) - with bigger outer CV joints.
40250-31G00/40250-32G00/40250-32G01/40250-31G10 - Any other T1/T2/Pathfinder (including VG30I engine, upto 1988)
So, if you plan to use the VG30E outer CV joints, you need hubs compatible with these numbers: 40250-88G00/40250-88G01/40250-2S610
In any other case, you need hubs compatible with 40250-31G00/40250-32G00/40250-32G01/40250-31G10.
I am using these (chinese copy of 40250-31G10, around 120EUR per set):
We've made a group order from china some time ago (around 2 years ago). I did not had any problems with them so far.
Another option is brasilian AVM (Superwinch are the same, only with different color and label on them) (around 150-200EUR per set). These are widely available from many sources in europe. But I find chinese are better than AVM.
Hope this helps.
- vincent sch
I don’t know if my Terrano I (US Pathfinder?) with VG30E engine is from after or before 1988.
My CV joints are with 28 splines; these ones are bigger in diameter than the original ones on the Terrano II.
Ok, you have right,
Are this Hubs made in steel? Not aluminum
I use usually AVM Hubs but they have a big problem, the boolts will open themselves by using them hardly on crossing.
I would be interested on those Chinese products, they seems to be a perfect copy of manual hubs. They seems to be stronger then AVM Hubs.
Have you an address? What about the transport costs and the custom taxes for importation? Are you sinking that an order for one set would interest them?
Thank you for your help and your knowledge sharing
Best regards
sparkybg
http://www.alibaba.com/trade/search?Sea ... t_en&fsb=y
120EUR was the price including DHL shipping+VAT+customs taxes. As far as I remember, we ordered around 10 sets for various models (Terrano, Frontera, Toyota, Trooper).
But you will have to use another number if you plan to use the VG30E outer CV joints.
Here (40250-2S610):
- vincent sch
Merci Bebop, j'ai corrigé dans mon inter. Espérons que Spartak comprendra mon anglais plus qu'approximatif.Bebop a écrit :canelures = splines, pas groove![]()
Sinon, ce matériel présente quand même pas mal d'atouts, il ressemble au corps des moyeux automatiques montés d'origine sur le T1. En plus, plus de soucis avec les petites vis conique de fixation du capot des AVM qui se grippent et cassent régulièrement. La ce sont des 6 pans de 8mm de diamètre qui viennent serrer l'ensemble sur le corps de la roue. Peut être que le fait de serrer le moyeu depuis le haut du corps du moyeu sur la roue limite le phénomène de desserrage observé systématiquement avec les moyeux comme les AVM et les Mile Maker ? A voir. En tous les cas, il y a de la matière et rien que cela, ça rassure.
- vincent sch
sparkybg a écrit :I forgot the exact supplier, but here are some suppliers:
Here (40250-2S610):
Yes this reference should be the ggod one but its aluminium alloy.
sparkybg
Only the outer body is aluminum. Take a closer look at my pictures and you will find out that none of the inside parts is aluminum. The outer body is not subject to any load/stress from the power train. It is just there to hold everything together. I am pretty sure that the original manual hubs are also with aluminum outer body - there is no need for anything stronger there.vincent sch a écrit :Yes this reference should be the ggod one but its aluminium alloy.Im not sure that this is the same that your ones. Your ones seems to be steel.
PP: As I said, I find chinese hubs better than AVM. I had AVM before the chinese ones. They didn't broke (well, two small pieces from the central part broke off, but still the hub was OK) , but their bolts (the bigger 6 bolts) were constantly self-perpetuating, and I nad to retighten them once every month. Moreover, the AVM have a bad seals and it is easy to fill them with debris and muddy water if you drive often on muddy grounds, rivers, and so on. AVM-s was in total rust after a month or two also. The paint is there only when you buy them from store. Shortly after this (say - first winter), they are all rusty.
PPP: My hubs are exactly the same with aluminium outer body. There are no more aluminum parts other than the outer body.
- vincent sch
But I have rusted pieces on the internal part which rust in the wheel.
If they would accept paypal it would be good.
Best regards
- Bebop
vincent sch a écrit : Rest more than to get in contact with them
