remplacement du différentiel du pont R180A par un Quaife
re: remplacement du différentiel du pont R180A par un Quaife
#141
Hi gte4x4 :)
You are coming from US. The Terrano II is named Pathfinder in the US. ;) We are using some parts of the Pathfinder to install them on our Terranos.
I had installed a reduction set on my gearbox coming from CALMINI
Here you can find the answers on your questions
http://www.forum4x4.org/showthread.php?t=55196
The axel on your photos looks like an R180A. ;)
It s coming from what kind of car if I can ask ?
Sorry for your difficulties to register on our forum. :(
Best regards
gte4x4
#142
Message par gte4x4 »
It's going into a kit car (build your own) right now, so I need to know what Pathfinder (thanks for that information) year has that exact differential. The axle in my picture is from an Ebay auction, so it is not mine.
Thank you for your help and for the link, I can't believe all of the measurements were already posted! :)
#143
I’m not sure, but it seems to be the Pathfinder 4WD SE WD21 from 1985 to 1995 on witch you have the more chance to find the same front axle. :hein:
Skalraf, peux tu fouiller un peu dans les plans éclatés que tu as pour regarder si le pont avant sur le Pathfinder US WD21 a bien un pont R180A ?
By
#144
vincent sch a écrit :I’m not sure, but it seems to be the Pathfinder 4WD SE WD21 from 1985 to 1995 on witch you have the more chance to find the same front axle. :hein:
By
Have you seen on the back of the page, on the left, you can choice the language. Perhaps this can help you a little. The English version is possible. It would perhaps help you for registration. ;)
Best regards
gte4x4
#145
Would you like me to take measurements for you like this for the US Xterra R180a? I know you are considering going to a US diff and I would be happy to return the favor you have done me! Let me know if I can help.
I did not see the link at the bottom that allowed you to switch the forum language to English, that is nice but well hidden. I tried to go through the steps of registering with the English version of the board, the random question is still in French and is copied below at the bottom, along with the google translation of the random question. The last line should read
Starting at the end count eleven lines backwards and then copy / paste the contents of that specific line only in the box below
instead of reading as
Starting from the end, climb least eleven lines, then copy / paste the contents of the line under çi below
which I know is google translates fault and not the fault of the forum, but that is what made it difficult for me to register, since I do not know French which I apologize for :) .
I appreciate the help you given me and if I can return that favor please let me know.
Random Question:
Ouvrez dans une nouvelle fenêtre de votre navigateur la page d'accueil du forum, allez ensuite dans le forum "Aide à l'inscription" et cherchez le sujet "Important : Aide à l'inscription : Forum". Le premier poste contient une liste de mots. En partant de la fin, remontez onze lignes moins une, puis copiez/collez le contenu de cette ligne dans le cadre çi dessous :
Random Question:
Open in a new browser window the forum home page, then go to the forum "Registration Help" and look for the topic "Important: Help for registration: Forum". The first post contains a list of words. Starting from the end, climb least eleven lines, then copy / paste the contents of the line under çi below:
#146
gte4x4 a écrit :Would you like me to take measurements for you like this for the US Xterra R180a? I know you are considering going to a US diff and I would be happy to return the favor you have done me! Let me know if I can help.
Hi, thank you, that would be an good idea to obtain the same mesurements from a R180A for a XTERA to see if it is the same. ;)
Yes, I'm looking for a QUAIFE dif, a QDF7L ARB, for R200A Nissan axle, perhaps could you tell me the best price you could find for this part ? :D But it's not easy for us to buy in the US, We have too many customs charges and fringe expenses because of the use of carriers such as UPS. Are they some sellers who use the services(departments) of the post office?
Ok I have understand the problem. :( We will see if we can make something.
Best regards
skalraf
Date d’inscription : mai 2007
Bijour,
#147
Message par skalraf »
vincent sch a écrit :....................
peu importe l'année & ou moteur :hein: ???
Il faudrait demandé un bon traducteur à webmaster pour ce topics ... J'ai pas toujours madame à coté & les thermes technique elle ne comprends pas tout :roll: :D :D :D
Terrano II 2,7TDi 2003
#148
En fait je cherchais à savoir quel modèle aux USA pouvait avoir un pont R180A identique au notre. Il semblerai que le XTERRA ait ce type de pont. Oui, peut importe l'année, faudrait voir si sur le Pathfinder il y a bien un modèle qui possède ce pont. Non ? :hein:
#149
#150
Dis Bebop, toi qui maitrise la langue, peux tu nous dire si je ne me suis pas trop planté dans les échanges en anglais. S'il y a des trucs a corriger pour que ce soit plus facile à comprendre pour notre ami. Ce serai sympa :)
