Caméra de recul
Modérateur : commando ricard
patric361
re: Caméra de recul
Message par patric361 »
Voici un copier/coller du descriptif et 2 photos:
Product Details
Item specifics
Wire or Wireless:
Wire
Brand Name:
tuao
Lens Material:
Plastic + Glass
Shell Material:
Plastic
Guiding Line:
Yes
Length of Video Cable:
6M
Material Type:
Abs
Alarm Type:
Rear Side
Model:
4LED Universal
Material:
ABS Plastic
Video Format:
NTSC/ PAL
Image Sensors:
PC 7070K
Effective Pixel:
40W Pixels/ 648 x 480
Features:
IP67 Waterproof/ With dustproof
Type:
Rearview Camera/ Rear View Camera/ Vehicle Camera
Applicable vehicles:
For Volkswagen Ford Peugeot Toyota Hyundai Honda Opel Universal &More
Angle:
140 Wide Angle
Product Description
TUAO Car Trunk Handle Vehicle Camera HD Rear View Camera for Audi A4 S5 Q3 Q5/ VW Passat Tiguan Golf Passat Jetta Touran TouaregUSD 19.49/100000015
TUAO HD CCD 4 LED Reverse Camera 140 Angle Universal Car Rear view Camera IP67 Waterproof Vehicle Camera for VW Ford Toyota&MoreUSD 6.49/100000015
TUAO TPMS Car Tire Pressure Monitoring System Solar Energy LCD Color Display 4 External Sensor Auto Alarm System Car electronicsUSD 51.71/100000015
TUAO 2017 Super Definition Vehicle Camera 170 Wide Angle Universal Starlight Night Vision Rear View Camera IP68 Reverse CameraUSD 24.79-25.41/100000015
TUAO S5 Car TPMS Tire Pressure Monitoring System Solar Energy Display 4 External Sensor Auto Alarm System Diagnostic toolUSD 59.99/100000015
TUAO 20mm Card Hole Vehicle Camera 140 Angle Universal Car Rear view Camera IP67 Waterproof for VW Ford Peugeot Toyota & moreUSD 6.99/100000015
TUAO TPMS Car Tire Pressure Monitoring System Solar Energy LCD Color Display 4 Internal Sensor Auto Alarm System Car electronicsUSD 55.19/100000015
TUAO TPMS Car Tire Pressure Monitoring System TY04 TFT Display Solar Power 4 External Sensor Auto Alarm System Diagnostic ToolUSD 63.74/100000015
The hole on the back of the camera is used to make the rubber medium (IP67 waterproof),
Using the technology: rubber to fill the gap.
Features:
1: View 140 degree super large visual range, reversing more secure;
2: With reverse reference line , the distance of the obstacle at a glance;
3: Installed in the rear handle and the license plate lights, equipped with self tapping screws;
4: -30 to +60 temperature range of application, fully in line with the application of automotive environment;
5: The factory after the high pressure water immersion test and 12 hours on the electrical aging test, multilayer waterproof design, truly high pressure washing and immersion;
6: Using CCD digital fill image sensor designed for automotive rearview development design, using digital fill and software technology, clear image in daytime, and lower at night;
7: Video cable connection monitor, power cable connection car tail light power supply, reversing, reversing monitoring system automatically start working, you can clearly see the car after the situation;
8: Applicable vehicles:For Volkswagen Ford Toyota Hyundai Honda Opel & more.
Specifications:
Effective pixels: 40W Pixels
Image sensors: PC7070
Minimum illumination: 1.5Lux / F1.2
Video output: RCA, 1.0VP - P. 75ohm
Working voltage: DC12V
Type: Rear View Camera
Waterproof level: IP67
Connectivity : Wire
Video format: NTSC, PAL
Package weight: 0.19 kg
Package Contents:
1 x Car Camera, 2 x Screw
1 x 6M TV Cable,1 x Power Line
Plus le Def 110 td4, mais un Jimny couleur kinetic yellow :) et une Suz V-Strom 650
CHRISV8
re: Caméra de recul
Message par CHRISV8 »
merci , mais ya pas d'écran avec ton truc :hein:
静かな強さ
omnibus
re: Caméra de recul
Message par omnibus »
J'ai posé ça ca résiste au lavage j'ai pas baigné encore
viewtopic.php?t=163230-Pose-camera-de-recul-T2?
2,7 Tdi court Fin 2002 AVM M
CHRISV8
re: Caméra de recul
Merci du retour ;)
静かな強さ
j-marc1
re: Caméra de recul
Message par j-marc1 »
CHRISV8 a écrit :Merci du retour ;)
salut
moi j ai mis ca!
simple a installer et j en suis tres content. ;)
Patrol Y 61 de 2005 Kit rehausse Ressorts KS HD Amortisseurs OME Sport Cooper STT 285/75/16 Treuil 5T9 Batt AUX Navigation embarquee Compresseur avec réserve d'air
patric361
re: Caméra de recul
CHRISV8 a écrit :merci , mais ya pas d'écran avec ton truc :hein:
Effectivement, la c'est juste la caméra :D en ce qui me concerne l'écran c'est l autoradio.
CHRISV8
re: Caméra de recul
patric361 a écrit :Effectivement, la c'est juste la caméra :D en ce qui me concerne l'écran c'est l autoradio.
on a pas les même valeur :D
静かな強さ
patric361
re: Caméra de recul
CHRISV8 a écrit :on a pas les même valeur :D
:lol: c est un cadeau :D
Samsara
Date d’inscription : juin 2016
re: Caméra de recul
Message par Samsara »
25€ le rétroviseur écran a poser sur celui d'origine + caméra
http://s.aliexpress.com/mM36ZJzq
40€ l'autoradio Bluetooth avec écran
http://s.aliexpress.com/aQnqAVna
CHRISV8
re: Caméra de recul
Samsara a écrit :25€ le rétroviseur écran a poser sur celui d'origine + caméra
jamais rien commander sur aliexpress , ça vaut quoi comme site ???
静かな強さ
