tu regardedeadyoda a écrit :COmment je fais pour savoir quel type de pont j'ai sur mon cherok ?
Sinon prend une photo et met la sur le post on te dira
Modérateur : valJeep
Donc un bête pied à coulisse dois te donner un indice supplémentaire; je crois que ce diamètre et la présence ou non de l'ABS doit pouvoir former un "faisceau de présomptions suffisamment fortes" pour avoir ta réponse.AXLES
The Model 35 axle is standard for XJ and YJ vehicles.
The 8 1/4 axle is available in XJ vehicles without ABS brakes.
IDENTIFICATION
Model 35 axle has the assembly part number and gear ratio listed on a tag. The tag is attached to the left side of the housing cover. Build date identification codes on axles are stamped on the axle shaft tube cover side. The Model 35 axle has a flat housing cover gasket flange at the outer edge.
The 8 1/4 axle has the build date code and gear ratio tags attached to the housing cover (Fig. 2). The housing cover gasket has a rolled gasket flange at the outer edge.
* The Model 35 axle has shaft tubes that are 2.625 inch (66.67 mm) in diameter.
* The 8 1/4 axle has axle shaft tubes that are 3.0 inch (76.2 mm) in diameter.
